287 hard drive to play through tv not computer
I use a Mac and have formatted hard drive so as i can transfer files onto it.
It works fine and always connects to my Mac straight away and shows that there are tv shows etc on the hard drive.
However, when I try to plug into my tv through the usb slot it does not recognise the hard drive.
Same with the set top box, it will say “usb detected” then when i go into media and try and play the files there is nothing?
I am really stuck, and its really annoying as I would like to be able to watch tv shows and movies which are on the hard drive through my tv.
Thanks
1 reply
