Hi
I have sansa clip plus 8GB and lately when i press forward to skip to the next song, the song just playing again from the start.
only after 10-12 presses it would skip to next one.
if i “leave” it to play the song- the next one wont play automaicaly, but pauses and then i have to press play.
* the “replay song” is off. and also the occures only in shuffle mode. if shuffel off- everything is OK.
What sould i do?
Thank you! 🙂
