My Book Essential 2TB 3.0 no auto power up on boot
I am using the My Book Essential 2TB 3.0 on a toshiba notebook running xp pro on a usb 2.0 port
I have the WD smart ware installed but the drive is not password protected & no backup software is set up because it is being used as an active storage drive for my network.
The drive its self works fine except for when I turn the pc off at night then boot up again the next morning the electronics in the enclosure do not appear to turn on when receiving a wake up signal during the boot process as no lights are on and pushing or holding the power button does not turn it on, I can however hear the drive spinning.
I have the sleep timer disabled through the WD smart ware program but it makes no difference, the only solution appears to be to un plug the power for a few seconds then re connect & the drive will power up & recognize by windows but it wil not become a shared drive with network access until I reboot the host PC.
I have 3 other external drives connected of different brands & all are left always connected & powered on, they all spin down when the pc is off fo a long period of time & all wake up properly on boot except for the My Book Essential.
Does anyone know if there is a solution for this or is it a hardware problem I am stuck with ?
Thanks, Joe
