Hi there
Up to now I have been using MyBook 2TB via my laptop (VISTA)
I used the MyBook in a click and drag way of transferring files straight to the file directory
Now we have a PC (XP 32bit)
MyBook mounts and I can access in MyComputer but it only shows I have 19.6mb on space (right click/properties) - When checked back again with Laptop, I haven’t even used up 1TB of space
I have downloaded the utilities/drivers and firmware direct from WD
But I can not access the data already held on MyBook
When MyBook initially loads; it has a pop up which states that the drive is not locked
I need MyBook to now work with the PC (XP) as the Laptop is now on it’s last legs (about 10 years old) and I do not want to loose all the data files on MyBook.
Please help
 MyBook Data Not Accessible
1 reply
