I just installed the software for my new WD Passport 4TB. After installing and updating, WD Discovery tells me “No USB devices connected”, and the WD Security and WD Drive Utilities applications tell me “Attach a supported WD drive”.
The strange part is, I can see the drive in Explorer, and I can copy files to and from the drive. The drive itself seems fine, but none of the WD applications can tell it’s attached.
I’m running Windows 10.
I’ve run through all the troubleshooting available through the WD knowledgebase with no luck.
