Passport Now showing as Local Disk and asking to be formatted
My WD passport now shows as local disk. and asks me to format it before i can use it… It shows RAW partition in disk management and also shows it’s healthy… i have tried to recover it using TESTDISK to no available.(have very IMPORTANT data in it that is tied to my job)…at a point, i was so frustrated that i wanted to format it, but windows couldnt format it. After that i saw online that PHOTOREC helps in recovery, i used it and it recovered very few file esp .txt, .pdf. but not the main files i NEED. Pls what do i do to recover these files as it may cost me my job. thanks
Note: Using Testdisk, it stops @ 74/121597 while scanning the cylinders, i dont know what that means or implies…
