I just began using my brand new Sansa Fuse, and I have this one question:
When I load tunes I ripped from homemade CDs such as “audience recordings” of live concerts, it comes up initially as “uknown album”, etc. But when I add the names for the album name and the song names, I can see them on my computer, and they show up again on my computer screen when I drag them onto the Sansa…but then when I go to play them on the Sansa, they are still labeled “unknown album”, or the like. When I plug the Sansa back into my USBII port, I can see the properly named albums and tunes in the window! So, the info is there, but it’s not visible properly on the Sansa screen. Nothing I’ve tried seems to fix this.
I am using a Dell laptop with Windows Vista as my operating system.
The Fuse manual says to right click on the file and select “properties”, and then select “Summary” tab…well, there IS no summary tab.
Any help would be appreciated! Thanks,
Matthew
