USB Mini Port broken on 1TB My Book Essential
Hello WD Community,
I have read several threads here on this subject. However, I have some specific questions that I did not find answers to in those postings.
The issue: Dog knocked HD off the coffee table and the sudden jerk caused the usb cord to break the usb mini connector inside HD. It is still attached to the board but the black insert (inside the mini female port) has broken off and one pin in seriously bent downwards - and may have broken off entirely. I could get the HD to be recognized on my laptop, but only for a second as I had to hold the usb cable in the exact sweet spot.
Anyway, I opened the casing (I’m no longer concerned about my warranty - just want my data) and obtained the PCBA # from the usb board and have found several boards matching this number on ebay.
Question 1: If I buy this board and install it, will it work? Or, is there info on the usb board in my HD that is specific to my drive and/or specific to the data on my drive? I understand that the data on the drive is dependent on the hardware, but is this referencing the small usb board or the larger board that is connected to the drive?
Question 2: If I take the USB board from my drive to an electronics repair person, can they easily solder on a new usb port? If so, do I try computer repair shops? Sorry, just don’t know who to reach out to for this. Also, will a place like this typically have the replacement usb port, or do I need to get that myself? Seems odd to order an $0.88 item over the internet.
My endgoal to get the drive running so that I can transfer the data to a 2TB drive in waiting.
Thanks for any help.
Brian
