Hi all ,š
Iāve had a friend pass me her WD drive as itās failed and will no longer be recognised in Windows.
Model: WD10TMVV-11TK7S1
Inside Windows Disk mgmt, it detects the drive however says ānot initialisedā, you try initialise the try and it says āError: Media is write protectedā.
The drive is just under a year old, has non-backed up data on it which she would prefer not to lose.
Anyone else had the same drive fail like this?, Iāve just been quoted $750-2500 NZD to fix =/
The drive has not been dropped at all and this started happening after a reboot.
Any recommendations would be appreciated, Iām presuming I need to use the data forensics guys just curious if anyone has expierenced the exact same issues, I couldnāt really get any definitive answers via google.
Cheers - Seth
