While it is an old product, with the rockbox firmware, it works great, and I would really like to buy an additional one, or if possible, just the front panel since the center button is failing on my device.
A dedicated mp3 player is a far better experience than using a smartphone, especially since it is easy to control the device by simply pushing the buttons through the pocket, and there is no fiddling with overpriced headphne cable remote controls.
